Entreq Vibbeater Vibration Absorber
Message non lu 31 mai 2019, 16:52
Je cite la prose du fabricant :D
if you remember your basic Physics lessons you will know that you cannot get rid of energy but simply convert it into another form. This is a fundamental law of physic's and of course nature. We have choosen a route that converts un-wanted energy into heat, as this is the least harmful to our precious musical signal.
‘Vibb eaters’ consist largely of our own dedicated copper-based sand mixture with the addition of small quantities of, amongst other things , specific precious metals. The properties of this mixture offers very interesting characteristics, particularly in the areas of magnetic fields, field effects, as well as dealing with physical vibration & surface energy. When you place a ‘Vibb eater’ on top of your loudspeaker speaker or on top of your electronic equipment the vibrations and various magnetic fields that come from the box's are absorbed, then through the mechanical friction between the copper granular mixture the excess energy is converted into very low level heat.
It's easiest to experience first hand the effect Vibbeaters have on your speaker by simply placing one ( there are a number of different sizes & weights for different speaker or electronic's cabinets) on top of your speaker while music is playing through them. Placing your hand on the speaker you should find that it is now almost free from vibrations but If you then move your hand/fingers and touch the ‘Vibb eater’ you will sense a great deal of activity, especially near the very top of the Vibbeater.
Guess where all the energy has gone ?
Through its weight it gives further stability to the speaker cabinet itself.
The vibrations and fields that are generated in the speaker box are most intense at the top of the speaker where the energy cannot go any further. When placing a Vibb eater’ on top of the speaker you are in essence extending the length of the speaker box to a critical point outside of the cabinet. The key is that that energy is no longer a part of the speaker itself. The Vibbeaters then simply absorb the energy and transforms it in to heat.
The magnetic characteristics that make-up the ‘Vibb eaters’ granular mixture can have a very positive impact on the fields generated in and around the loudspeaker itself.
In summary the treble tones become cleaner and free from the overtone distortion's of a vibrating baffle. The bass becomes quicker, tighter and with a deeper more textured sound. Above all the sound picture is widened which should give you a more precise position in width, depth and altitude. Last but not least there should now be a flow and a calm in the sound.
Apollo Vibb eaters
These use an enhanced mineral mixture which increases the performance available from this energy and vibration controlling product range.
Type of Vibbeaters:
Vibbeater Ultra (Each) 1kg/ each – for Cd player, Pre-amps etc
Vibbeater Mini (Pair) 2kg/ each – for equipment around 15kg
Vibbeater Midi (Pair) 3kg/ each – for equipment above 20kg
Vibbeater Maxi (Pair) 4kg/ each – for equipment above 30Kg
Vibbeater Jumbo (Pair) 6.5kg/each – for equipment above 40Kg
Vibbeater XX Apollo (Pair) 7.5kg/each – special energy absorbing mixture
Prix entre £95.00 et £740.00 :pouce: ben voyons manquerait plus que ça coûte des clopinettes , ça ferait pas sérieux :evilred:
Modifié en dernier par Gaston le 31 mai 2019, 17:17, modifié 1 fois.
Message non lu 31 mai 2019, 17:02
:lol: Mes peluches sont plus mignonnes et moins relou !
Message non lu 31 mai 2019, 17:09
demande a Ipodz ce qu'il en pense
Message non lu 31 mai 2019, 17:16
Stef Ledarp a écrit :
31 mai 2019, 17:02
Oui mais est-ce qu'elles transforment les vibrations en chaleur ? Hmmm ? Et est-ce qu'elles neutralisent les champs magnétiques aussi ?
Message non lu 31 mai 2019, 17:23
in French et € (mais ça date un peu)
Vibbeater Jumbo (paire) 6,5kg/pce - pour équipement >40kg au prix de 220 €
Vibbeater Maxi (paire) 4kg/pce - pour équipement >30kg au prix de 190 €
Vibbeater Midi (paire) 3kg/pce - pour équipement >20kg au prix de 175 €
Vibbeater Mini (paire) 2kg/pce - pour équipement 10-20kg au prix de 160 €
Vibbeater Ultra 1kg/pce - pour électronique, lecteur CD au prix de 85 €
Vibbeater XX Apollo 7,5kg/pce - mélange spécifique, pour grosse électronique au prix de 650 €
Fledermaus
Message non lu 31 mai 2019, 17:46
Pas cher !
Ils sont balèzes chez Entreq, https://www.entreq.com/products-17663461 , ils font aussi des câbles de course et des grounding boxes magiques en bois d'arbre, ici en plus de iPodz il y a dcc qui est bon client chez eux il me semble... :pouce:
Message non lu 31 mai 2019, 17:56
Fledermaus a écrit :
31 mai 2019, 17:46
Pas cher !
Yes
et pour les Dampling Plate HRS, dont Lariflette est un fervent défenseur aussi
Message non lu 31 mai 2019, 17:57
31 mai 2019, 17:46
Pas cher !
Balèzes ??? Connait pas comme arbre :ko: le mélèze oui :D
GWN
Message non lu 31 mai 2019, 17:58
Du coup on lance le concours des bidules les plus insolites à poser sur ces enceintes ? Et ce sans dérapage ?
Message non lu 31 mai 2019, 18:00
Heuuuuu là on parle de choses sérieuses :D t'as vu le prix :ko:
Message non lu 31 mai 2019, 18:03
Et si on a la phobie des rongeurs on fait comment ???
A moins que la forme "rat dodu" ait été validée à l'écoute pour son apport supérieur vs d'autres formes après de longues écoutes comparatives :lol:
Message non lu 31 mai 2019, 18:08
les rats quittent le navire avant la débacle
Message non lu 31 mai 2019, 20:02
Ahhhh ça, pour se moquer y a du monde... :ko:
Perso, le modèle 2kgs sur mes Studio Lab (6kgs) a été des plus efficace. Bye bye effet boomy, lisibilité accrue des lignes mélodiques, sensation de dynamique décuplée, présence des interprètes plus affirmée, propreté generalisée...
Sur les Folia, résultat moins spectaculaire (elles font 3kgs de plus que les Studio !) mais propreté et précision du rendu en hausse, image plus détaillé...
Je me répète mais les "modifications" qui ont amélioré le plus le rendu sonore de mon système (ancien et actuel), il y a en 1/l'ajout d'une bibliothèque Billy, en 2/les Vibb Eaters, en 3/le noren au mur et en 4/le jumper acier de mon ex Yamaha reliant la section pré/amp remplacé par un jump Hifi Cables & Cie...
Quand pour 160€ la paire de Vibb, vous faites passer vos biblio de 140€ à un rendu d'enceintes valant plutot 600/800€, le calcul est vite fait... :evilred:
Et pis j'vous l'demande, pourquoi quand on teste des câbles serait-on plus crédible que quand on leste nos appareils ? :comprendpas:
Message non lu 31 mai 2019, 20:34
Ah désolé je savais pas que t'avais ça :ko:
Certes je comprends bien qu'alourdir des enceintes de 5-10kg peut être bénéfique pour les empêcher de danser . Mais pour 10€ t'as 10kg de patates et ça fera sans doute pareil :D
:evilred:
Modifié en dernier par Gaston le 31 mai 2019, 20:37, modifié 1 fois.
GWN
Message non lu 31 mai 2019, 20:36
Parce qu'un sac de sable dans une jolie poche non étiqueté audiophile ferait l'affaire ?
Mais je dis ça, je dis rien...
Modifié en dernier par GWN le 31 mai 2019, 20:36, modifié 1 fois.
Message non lu 31 mai 2019, 20:54
Gaston a écrit :
31 mai 2019, 20:34
:evilred:
5-10 kg peut être pas pour des enceintes de 10 a 20 Kg
et pis, tailler des oreilles, des moustaches et une cravatte dans une patate c'est pas a la portée de tout le monde :ghee:
Message non lu 31 mai 2019, 21:01
Moi j'adore leur gueule !
Si je peux en toucher 1x en occaz à vil prix, je craquerais...
Anthem MRX-740
SVS SB-2000 pro
Message non lu 31 mai 2019, 21:24
Justement y'en a deux à vendre sur le bon 🐽 c'est là que j'ai découvert . Je savais même pas que ça pouvait exister des trucs pareils :D
Message non lu 31 mai 2019, 22:50
Vous êtes que des jaloux... c'est moche !!! :mdr:
GWN
Message non lu 01 juin 2019, 18:50
Oui moche comme une souris qui s'est vue aussi grosse qu'un boeuf.
