alfred hitchcok
Exhausteur de goût
Message non lu 25 déc. 2018, 22:56
Bonsoir à tous, j'ai installé le bluesound Node 2 que j'ai acheté sur le site d'E&M, j'ai tout ce que je voulais, les Webradio, Napster mais rien sur mon DD branché en USB, il le lit bien, les albums sont là mais rien à l'intérieur
Dossier --USB---tous mes dossiers y sont---artistes---albums----content not Found !!!
tous les albums sont encodés en FLAC. sur mon OPPO 93 ça marche bien pourtant tout y est reconnu
est-ce quelqu'un peut m'expliquer ce qui ne va pas ,
merci à tous :ohmg:
Ampli Gato 250s Npm
Micro Seiki
Zappiti 4 K HDR
thierry94
Message non lu 25 déc. 2018, 23:18
quelques éléments ....
https://support1.bluesound.com/hc/en-us ... al-Library
Connection to USB 2.0 device. Devices requiring greater than 0.5A of power will require a USB Powered Hub or external power supply. See Notes for more details.
The USB port can be used to connect USB memory sticks holding music, which can be played and listened to on a local BluOS Player. USB stored music can also be grouped to playlists and streamed to other Players in the ecosystem, as long as the local Player connected with the USB storage device is the Primary Player in a Group.
BluOS Players will index and play music from USB mass storage devices formatted as FAT32, NTFS or Linux ext4 but with limitations. The index of these units, by design, is limited and sometimes unstable. USB Mass storage devices are designed for plug-and-play storage, not for an extended or permanent storage solution. For a more stable, permanent solution, Bluesound strongly recommends network sharing from a local PC, Mac, Network Attached Storage (NAS) or Bluesound VAULT or VAULT 2.
If you have questions about USB storage and how it differs from a Local Library, or if you encounter technical problems, please contact the BluOS Support Crew by opening the Navigation Drawer in the BluOS Controller app and select Help > Send Support Request or by submitting a request at the bottom of this page.
bonnes fêtes a tous :pouce:
Modifié en dernier par thierry94 le 26 déc. 2018, 22:54, modifié 1 fois.
Visit Here/>
alfred hitchcok
Exhausteur de goût
Message non lu 26 déc. 2018, 09:52
Merci pour cette réponse mais je ne vois pas Bluesound faire du cas par cas. je vais regarder comment j'ai formaté mon DD sur mon Mac, tenter sur un autre voir ce qui se passe.
est-ce que je suis le seul à avoir ma musique sur un disque dur? je ne veux pas de Nas, j'ai du mal avec les intégrations réseau j'avoue.
Pendant que j'y suis mon préamplificateur n'a pas d'entrée optique ou spdif, est-ce utile d'y ajouter un convertisseur afin de brancher le Node2 en numérique?
pour l'instant il y est en RCA de très bonne qualité.
merci
Ampli Gato 250s Npm
Micro Seiki
Zappiti 4 K HDR
thierry94
Message non lu 26 déc. 2018, 11:01
" je ne vois pas Bluesound faire du cas par cas ..."
ben il faut tenter ... c'est le principe d'un support technique ? :help:
j'ai occasionnellement branché en usb un Samsung DD Externe SSD T5 (500 Go) sans souci ....
en réseau ...box free révolution aussi sans souci particulier ...
pour la partie réseau c'est pas très compliqué , juste des autorisations de partage dossier a paramétrer pour mon cas ( win 7 )
Visit Here/>
alfred hitchcok
Exhausteur de goût
Message non lu 26 déc. 2018, 11:56
Mon disque dur est un Toshiba de 1 To. formaté sous Mac, le format est un MS-DOS FAT 32.
pour la partie réseau tout fonctionne très bien, merci
je retente ma chance sur ce point. Mon préamplificateur n'a pas d'entrée optique ou SPDIF, y a t'il un avantage à acheter un petit convertisseur?
si oui auriez-vous un modèle à me conseiller?
merci :pouce:
Modifié en dernier par alfred hitchcok le 26 déc. 2018, 12:31, modifié 1 fois.
Ampli Gato 250s Npm
Micro Seiki
Zappiti 4 K HDR
Hifitub
Message non lu 26 déc. 2018, 12:21
On demande M. Nagual ! ;)
alfred hitchcok
Exhausteur de goût
Message non lu 26 déc. 2018, 16:24
Si Nagual pouvait me renseigner également ce serait sympa.
Je viens d'acheter un autre DD de 500 Go et la musique passe bien alors que mon autre DD de 1To ne passe pas. Les autres sont au même format MS-DOS FAT32.
par contre les pochettes ne s'affichent pas.
Ampli Gato 250s Npm
Micro Seiki
Zappiti 4 K HDR
nagual
Message non lu 26 déc. 2018, 16:55
Bonsoir à tous :)
@alfred tu aurais une image des repertoires de ton DD ? (impression ecran).
est ce que tous tes repertoires sont à la racine du DD ?
Est ce que tu peux faire un click droit sur un dossier qui contient ta musique et regarder quels sont les attributs du repertoire? (regarde si "caché" n'est pas coché).
alfred hitchcok
Exhausteur de goût
Message non lu 26 déc. 2018, 17:15
Merci Nagual de ta première réponse, voici une photo de mon DD De 1To.
Image voici les différents dossiers
j'espère que c'est bien ça.
Ampli Gato 250s Npm
Micro Seiki
Zappiti 4 K HDR
nagual
Message non lu 26 déc. 2018, 17:49
tu peux regarder ce que tu as dans "partage et permission" ?
essaie de cocher "dossier partagé"'
apres est ce que tu as une alimentation externe sur le HDD 1To ?
si oui branche la plutot que alimenté par le port USB
alfred hitchcok
Exhausteur de goût
Message non lu 26 déc. 2018, 19:06
Merci Nagual, j'ai transféré une partie de mon DD de 1To sur mon petit de 500 Go, la moitié à peu près et ça marche
pour la case partage et permissions, ça dit seulement que je dispose d'un accès personnalisé.
j'ai coché la case dossier partagé mais ça ne change rien.
j'ai toujours ce message error folder directory--content not found
est-ce la taille du DD? alors qu'il est bien lu en l'état par l'OPPO en usb également.
Ampli Gato 250s Npm
Micro Seiki
Zappiti 4 K HDR
nagual
Message non lu 26 déc. 2018, 23:40
Je ne pense pas que la taille soit le problème
Peut être une question de temps
As tu laisse le dd branche un peu ?
Des fois il est lent a lister les répertoires.
thierry94
Message non lu 27 déc. 2018, 00:01
vérifier si il n'existe pas une "mini partition " constructeur Toshiba et ou logiciel propriétaire intégré au DD ?
si oui , écraser celle-ci ...ensuite re partition totale unique + formatage ( tenter en NTFS ) ....
+ alim séparée !!
Modifié en dernier par thierry94 le 27 déc. 2018, 16:03, modifié 1 fois.
Visit Here/>
alfred hitchcok
Exhausteur de goût
Message non lu 27 déc. 2018, 14:00
Merci pour ces précisions, j'y ai pensé, j'ai déjà transféré sur mon petit DD de 500 Go à peu près 300 Go, je vais voir pour transférer sur un autre mais là c''est compliqué, je n'ai pas tant de DD d'avance.
formaté à nouveau celui de 1To et voir ce qu'il se passe par contre je n'ai pas de DD avec une alimentation séparé. à voir autour de moi si je peux m'en faire prêter un.
@+ et bonne journée à tous.
Ampli Gato 250s Npm
Micro Seiki
Zappiti 4 K HDR
brice39
Message non lu 28 déc. 2018, 10:17
J'ai une petite question, peut-être bête pour certain.
J'utilise mon BLUESOUND NODE2 en WIFI depuis ma box, vais-je gagner en qualité si je passe en filaire RJ45 ou pas nécessaire
(Pour info la box n'est pas dans la même pièce).
Merci.
alfred hitchcok
Exhausteur de goût
Message non lu 28 déc. 2018, 13:35
brice39 a écrit :
28 déc. 2018, 10:17
Merci.
Désolé Brice, je n'ai pas tenté en wifi, je suis en RJ45 la box est juste posé à 2 mètres à peine.
Ampli Gato 250s Npm
Micro Seiki
Zappiti 4 K HDR
alfred hitchcok
Exhausteur de goût
Message non lu 28 déc. 2018, 13:47
je ne m'en sors pas. sur le petit Seagate de 500 Go hier soir avec un dossier de 250 Go tout marchait bien.
entretemps j'ai formaté à nouveau mon DD Toshiba de 1To, mis deux albums et là miracle ça fonctionne. hier soir je continue et je lui colle 280 Go et là patatras ça ne marche plus.
je reprends le petit seagate et ça ne marche plus. ça commence à me chauffer. :grrr: :mnrv:
c'est dommage parce que les webradios ça fonctionne bien, Napster également, le son est très bien. Dans la série je continue hier sur mon iPhone X l'appli me donnait accès à la moitié du Bluesound.
j'avoue je crise grave.
Ampli Gato 250s Npm
Micro Seiki
Zappiti 4 K HDR
Atchoum
Message non lu 28 déc. 2018, 13:55
Il faudrait essayer un formatage en exFAT plutôt que FAT32.
nagual
Message non lu 28 déc. 2018, 14:44
@alfred
fais un petit reset du bluesound (debranche, rebranche le).
branch ton DD et laisse le un peu branché le temps qu'il repeuple les repertoires
thierry94
Message non lu 28 déc. 2018, 14:56
Brice
oui je pense que tu vas y gagner surtout en stabilité :zen:
c'est d'ailleurs une évolution du node 2 i amélioration du wifi (nouvelle puce) :pouce:
" Further, Bluesound has updated all three Gen 2i models to a dual-band WiFi chipset for 2.4Ghz or 5GHz connections "
https://darko.audio/2018/10/bluesound-r ... vault-2i/
bonnes fêtes
Modifié en dernier par thierry94 le 28 déc. 2018, 16:21, modifié 2 fois.
Visit Here/>
